Hi all,
I'm having trouble with the torsion spring again. i need to create a torsion spring that has a deflected angle. I managed to do that by using Michael's suggestion- changing the length of the spring. My pitch value = diameter of the cross section. But i can't add the ends. If it's normal to axis, the end protrusions will overlap the spring and WF2 is not allowing me to do that. If i have it normal to traj, i don't know how to add the ends since i can't pick any datum plans to be my sketch reference.
Is there any other way i can construct this torsion spring? Or is it something i am doing not right?
Thanks!
