I am trying to calculate what size torsion spring I need to move a 40 lb load. If you look at the following link you can see the application.
I have used the Eng Edge calculator but am not sure if I used it correctly. I have 35 degrees to push using a 180 degree torsion spring. The cutting head weighs 40 lb. The moment is 2". This gives me a spring constant of 2.2857 (lb-in/deg) "K".
Is this "K" value equal to the "torque in/lb" found in a spring catalogue? If not, how do I equate this "K" value to that torque rating.
Thanks in advance,
Todd
Thanks in advance,
Todd
