When working with CMU cavity walls, people in my office often specify steel I-beam lintels centered over the CMU. Bottom plates are welded to them to support the brick facade at an eccentricity dictated by the geometry involved.
I'm concerned with the torsion that is introduced into the system with this design. I've no problem with designing the lintels for torsion if necessary; however, I don't understand how the torsion in the lintels gets transfered out to the masonry walls at the bearing points.
It has occured to me that, once rotation occurs in the I-beam, the weight of the masonry above the beam would rest on the inside of the top flange and create some counteracting torque. However, considering the typical geometries involved, this resisting torque hardly seems adequate.
So what is left then for resiting the torque? All that I can think of is the tensile capacity of the mortar and I don't think that it would be wise to count on that. Does anyone have any suggestions? Perhaps I a missing something significant in the way that I am visualizing the situation? Any help would be greatly appreciated. Thanks
Adam
Adam
