GalileoG
- Feb 17, 2007
- 467
Please refer to the sketch attached to this post of two connections as an example.
Say I have two connections. One beam to beam and the other beam to column connection. The beam in both connections experiences torsion, which produces a force-couple on the top and bottom flange (which are connected using "cover plates")
There is an eccentricity between the 3 sided weld group and the single fillet weld on the girder beam/column.
My question would be, how is the torsion produced by the eccentricity of the force (M/d) shared between both weld groups in both connections? How do you determine that?
I would assume for the beam to column connection, I will have a moment on the column to cover plate joint equal to M/d * e (it takes all of it since the column is alot more stiff than the beam) whereas the beam to beam connection, the moment produced by the eccentricity is distributed between both weld groups, but to what extent, I don't know.
Can someone please elaborate? How can I quantify/calculate all of this? Is my basic understanding correct?
Clansman
If a builder has built a house for a man and has not made his work sound, and the house which he has built has fallen down and so caused the death of the householder, that builder shall be put to death." Code of Hammurabi, c.2040 B.C.
Clansman
