qtrhorse
- Sep 8, 2006
- 17
I have CAT-50 tool holders that have a 1"-8 thread pull stud with a 110 ft.lbs. max. torque spec. This seems quite sufficient if the threads were always dry. However, between the spindle oil and the oil in the coolant, in takes about 150 ft.lbs. to get the same results, a formula or lab test backed data sheet would be nice to justify.
