Guest0527211403
I'm reviewing my company's existing standards for our fastener torque specifications, particularly as they apply to our metric SHCS' in aluminum castings (AA356-T6 material).
I understand that under specific loading conditions, we need to review the bolt torques in detail based on the strength of the materials and the applied loads.
However, in some applications we use brackets that are used to mount sensors and other items to the casting (i.e. there is no special loading, only machine vibration.) In such applications, I'd like to start working with a "general purpose" torque table based on fastener size.
Is anyone aware of a standard or document (I've been looking at Aluminum Association and various other organizations' standards with no luck) that has some recommended torques into aluminum castings? My plan is to use this as a starting point, take a scrapped casting, tap some holes in it and make sure our more experienced assemblers are ok with the torque specs.
Thanks in advance,
Thanks in advance,
