Jaydeep_G
- Nov 9, 2020
- 2
I am stuck at the procedure to find the required torque to rotate the shaft with eccentric masses attached with it. Following are the inputs that I have
Mass of rotating system= 14kg
rpm= 4000
M.I.(through axis of rotation)=0.008 Kg-m^2
Eccentricity from CG to axis of rotation= 4mm
As shaft rotates at constant rpm, so angular acceleration is zero.
I calculated as follows, but I don't know this method is right or wrong.
As the torque is rate of change of angular momentum, T=(Iw2-Iw1).......(w2 and w1 are final and initial angular speeds respectively)
And at start, w1=0 hence T=Iw1
Am doing this correct or not? Please suggest the correct approach to get to the answer. Any advice would be greatly appreciated.
Thanks and regards,
Jaydeep G
rpm= 4000
Thanks and regards,
Jaydeep G
