kingnero
- Aug 15, 2009
- 1,779
I know bolt calculation is only as correct as the guesses towards the K-factor,
however just for an indication:
What would be the pressure generated by a certain torque on the handle of a C-clamp?
Is this formula valid?
T = K F d
with d = nominal diameter of the threaded section
or is this one correct?
T = K F p
with p the pitch distance
as mentioned here ( a random google search)
I hope you will understand the question without the need for a drawing or a sketch, just imagine you're trying to squeeze a bathroom scale with a regular C-clamp...
T = K F d
T = K F p
