Torque Coefficient
MechiShrike
I am trying to estimate the torque that will cause the screw threads to strip out of an aluminum heat sink. I believe I have everything nailed down except for the Torque Coeffecient, K. The value can range from .09 to .35 or so, which makes a huge difference in the failure torque.
Does anybody have a good feel for what a good number would be for zinc-plated screws into A380 cast aluminum?
Thanks for any help,
Shrike
If the zinc plating does not have any further treatment, then I would guess around 0.3.
Cory
Thanks Cory. That helps a lot. The numbers I was getting seemed too low, but I couldn't find a good excuse to use a value higher than .22 or so.
There's just not a lot of documentation out there.
Thanks again,
Shrike
Thanks for the tip and I plan to, but my boss wants theoretical numbers. He says we'll test later...
He's not a fan of torque tests. He's worried about variations from the driver slipping in the screw head.
Personally, I hate plugging numbers into non-imperical formulas and running with the result.
The driver slipping in the screw head is way down the list of variables that are likely to affect a torque-tension test. As far as documented numbers, you can get some from Handbook of Bolts and Bolted Joints published by Dekker:
Cory
