WaxhawFive
- Nov 4, 2009
- 3
I have a simple timing application that the customer wants to solve with an Automation Direct CLICK PLC. I need to "measure" the time difference of two different discrete inputs. The expected time gap will be from 0 to 60ms. I know that resolution will be a function of scan time, since there is no high-speed timer module, so I'll be essentially counting scans between the two inputs. If I can get 10 counts in 60 ms, that will be enough resolution. It will be a very small program, so do you feel that I can rely on 6ms scan times or faster from this PLC? Or should I punt and suggest some other hardware?
