Belanger
Automotive
- Oct 5, 2009
- 2,450
I stumbled across a statement in Y14.5-2009 that doesn't sound quite right at first. Check out paragraph 5.4.1.2 on page 91, where it says: "Where the straightness tolerance is used in conjunction with an orientation tolerance or position tolerance value, the specified straightness tolerance value shall not be greater than the specified orientation or position tolerance value." Here's why that statement seems strange...
Think of a pin attached to a flat base, where straightness and perpendicularity are both applied to the FOS. I want to disagree with their statement because a straightness tolerance zone is controlling the derived median line, whereas the perpendicularity tolerance zone is controlling the axis of the UAME. The toleranced items aren't fighting each other, so why does the standard make the rule about the tolerance values?
The only thing I can think of is that having a larger straightness value would create an outer boundary that is larger than the perpendicularity's outer boundary. While not illegal in itself, having the form's boundary be larger than the orientation's boundary seems to violate the "hierarchy" of things, thus their rule. Or do you all have any other thoughts?
