Tolerance Stackup Validation
aszepesi
81
Where could I find the Tolerance Stackup Validation toolbar?
I remembered that It was a environment in NX6.
The help says: Analysis→Tolerance Stackup Validation, but there is not there.
The best way to find something is to use the "command finder"
Help (pull-down) -> Command Finder
It is also on your "Standard" toolbar.
You may be running a role that does not include access to everything (a limited role or 'essentials' role). Try changing to a role with 'full menus' and see if that helps.
