Gouge damage was blended from a web. The deepest blend is 0.020 inch. The blend was accomplished at 20:1 taper ratio. Nominal thickness measured of the web is 0.103 inch.
The material type and stock size is stated on Boeing Part List. The stock thickness as stated on Part List is 0.1 inch.
On the applicable Boeing drawing for the web, no where is the web thickness shown. The drawing gives a generic tolerance on page 1 of the drawing as +/- 0.03 inches. Can this drawing tolerance be used to justify the 0.02 inch blend as being within the drawing tolerance?
