Disregard my previous post. I clicked the "Submit Post" button by accident. It looks like only one file can be uploaded in each post.
I've created a fictitious part that is loosely based on the one in the original post. Please see the file named nominal.jpg. Datum features A and B are the hatched areas at each end of the part. The nominal centerline is also shown.
The other 3 files depict an imperfect actual part, being fixtured in 3 different ways according to 3 different datum referencing schemes. Simulators A and B are basically located relative to each other, and the jaws are symmetric about the nominal centerlines at the datum areas. I deliberately left out datum feature C, as it is not necessary since A and B constrain all 6 degrees of freedom. I also deliberately left out anything to do with datums and datum reference frames - we can deal with that separately.
The file A-B.jpg shows the part in the controversial A-B scheme. The idea is that both simulators have been tightened simultaneously and at the same rate. Neither simulator aligns fully to its datum feature. The part has problems in the middle, but does not have really large deviations anywhere.
The file AB.jpg shows the part location if A was referenced as primary and B secondary. The A simulator has been tightened first, fully aligning with its datum feature. Simulator B was tightened second, and only touches its datum feature on one side. The position of the part is very different from that of the A-B scheme. The requirement to align to the relatively short datum feature magnifies the deviations at the other end.
The file BA.jpg shows the situation with B as primary and A as secondary. The position of the part is different again, with the deviations magnified the other way.
One key assumption in all of this is that the part remains rigid and is not deformed to conform to the fixture. This is the default condition in Y14.5, and applies unless the drawing has a note describing the restraint condition. Based on some of the recent posts, the real parts are most likely non-rigid and are being deformed to some degree when fixtured. This might explain some of the assertions that there is little or no difference between AB, BA and A-B - the parts are being deformed the same way in each case. However, if the parts were being inspected in the free state using a CMM, these datum referencing issues would be very significant.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
