To get dimensions in Note/excel sheet directly?
  • Thread starter Thread starter rk_drdo
  • Start date Start date
R
rk_drdo
Guest
Hi everybody can u give me solution for the below question?
1) I want all dimensions displayed in a drawing
file into a note pad/exell sheet with their ids.
2) In assembly i have assembled two cylinders
of different dias with their central line as assemblyconstraint.
I create two datam points on two cylinder surfaces at
intersection of an assembly plane .I need the distance
betn these two points(distance-dimensionalvalue) in a note pad /excell
sheet directly.
my mail id is rk_drdo@yahoo.com please help me.
Radhakrishna Kulkarni
hello
have you seen the option Info >Model, Save as *.inf.
This file can be opened by an Excel but it is not associative.
Hope this helps, but i will check again the option to have an export fully associative file exported by proe, every time.
xcad
If you have Analysis in the menu then you can do it with Excel analysis ( It comes with Behavioural Modeling )
