TO FIND CONCRETE DAMAGE PLASTICITY MATERIAL PROPERTIES FOR STEEL FIBRE REINFORCED CONCRETE BY USING EXPERIMENTAL STRESS STRAIN RESULTS
Shreyas M
Student
Apr 29, 2025
4
How to change material properties of Concrete damage plasticity model for STEEL FIBRE REINFORCED CONCRETE in abaqus software??
i.e., Plasticity-Dilation angle, eccentricity,k, viscosity parameter,fbo/fco
Compression & tension behaviour and compression & tension damage.
I have stress strain results of experiment only.Where can I get formulae to find all of the above values by just using experimental stress-strain results?? I would just change the material properties of CDP model and not create steel fibre as a part and randomly orient it and then assemble it.I would be varying steel fibre volume fraction and using hooked end steel fibre.
Please help me in solving this problem.
