to create polyline in catia using VB
nizammuaidi
Automotive
MY
Hi there,
I have search around this forum to create the polyline in CATIA using VB. What I found was reversed process (create the point from polyline).
[blue]My question is, how can I set the VB code to be repeated to create the polyline until the end of the point that I have created?[/blue]
Below is the macro that I have reorded from CATIA.
Set hybridShapePolyline1 = hybridShapeFactory1.AddNewPolyline()
Set hybridBodies1 = part1.HybridBodies
Set hybridBody1 = hybridBodies1.Item("Geometrical Set.1")
Set hybridShapes1 = hybridBody1.HybridShapes
Set hybridShapePointCoord1 = hybridShapes1.Item("Point.1")
Set reference1 = part1.CreateReferenceFromObject(hybridShapePointCoord1)
hybridShapePolyline1.InsertElement reference1, 1
Set hybridShapePointCoord2 = hybridShapes1.Item("Point.2")
Set reference2 = part1.CreateReferenceFromObject(hybridShapePointCoord2)
hybridShapePolyline1.InsertElement reference2, 2
hybridShapePolyline1.Closure = False
Set hybridBody2 = hybridBodies1.Item("Geometrical Set.2")
hybridBody2.AppendHybridShape hybridShapePolyline1
part1.InWorkObject = hybridShapePolyline1
part1.Update
Can anybody expert entertain my question? I really stuck. [ponder]
Thanks.
where is the problem?
make a loop - for/next around:
Set hybridShapePointCoord2 = hybridShapes1.Item("Point.X")
hybridShapePolyline1.InsertElement reference2, .X
Eric N.
Hi.
Eric and Fernando,
[blue]Thanks for your kind reply.[/blue]
For loop statement, I am able to call the points from excel data as below:
'retrive data from excel
sp = 32
For i = 1 To npoints
x = Excel.Cells(i + sp, 4).Value
y = Excel.Cells(i + sp, 5).Value
z = Excel.Cells(i + sp, 6).Value
[green]However I don't have any idea how to call points from catia tree (as per attachment). I have tried to do looping on the polyline syntax as Eric suggest but it didn't works.[/green]
To be frank, this is my first time doing programming and I don't have any programming experience before.
Hope you guys can help me as a beginner.
 http://files.engineering.com/getfile.aspx?folder=96d55e3f-60dc-4e8a-8ee9-cb097b04446d&file=catia_points.jpg
why don't you get a VB/VBA book ?
VBA for dummies is very good. You will learn much more and faster from the book than from the forum (at least when you start learning)
Eric N.
BTW I am really helping you by telling you to get the book!
Eric N.
Eric,
Thanks for your suggestion. I just get the book and will start exploring the book. :-)
very good!
let us kow if you find a solution.. if not i will make sure you find a solution.
At the begining I used the object explorer very often.... be curious and look at the content of a sketch
Eric N.
