I want to add a circular beam and slab section on the top of the existing slab. But i am confused on how to create a connection between this two things. Should we assign constraints or is there some way to model it?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I want to add a circular beam and slab section on the top of the existing slab. But i am confused on how to create a connection between this two things. Should we assign constraints or is there some way to model it? said:The beam and slab section would seem like this
Physically you shall provide shear connectors between the ring beams and the slab to make it a composite structure. On computer modeling said:Thanks for your reply. Are you talking about the constraint? As the new beam slab element is supported on the slab i am not sure on how to assign constraint in such scenario.
The major assumption you would making here is that there is sufficient mechanical anchorage to allow the slabs to work as one composite. That would need to be checked by hand. said:Physically you shall provide shear connectors between the ring beams and the slab to make it a composite structure. On computer modeling said:I provide the constraint at the lower beam and the new beam and slab. however, the two slabs are deforming in different method on analysis. Is there any way to connect two slabs together?
John said:the existing slab is not able to bear the load so extra thickness is provided at that circumference which will help distribute the load and prevent punching. Actually the new liner load is a circumferential load and i distribute it to a new slab
Can you provide cross sections with note on member material and size? said:I'm sorry this doesn't make sense to me. How is the load of concern applied? It's a circumferential load? Some sort of fluid pressure? Explain how load is transferred into the slab. said:i have attached the cross section of the structure. Actually, the liner is supported on the centre beam which trasfers load to the slab and the lower beam and column
