a customer is asking me to repeat the shell test on all my trunnion mounted ball valves, for the simple reason that during the seat test we are removing the cavity vent device and putting it back
now this is something new to me
API 6D asks for checking seat leakage through cavity drain or vent, but it does not ask to retest the shell afterwards
attached the cavity vent plug design
basically it consists of a needle valve, actuated by the plug rotation
in my opinion this is not to be considered a pressure retaining part, but a pressure controlling part, hence the simple operation of venting the body cavity does NOT invalidate the shell test previously done
also, this vent has been designed as per API 6A par 10.11 figure 19. API 6A states:
10.11.4 Testing
The equipment furnished under 10.11 is not regularly subjected to a hydrostatic test, but shall be rated for the
hydrostatic test described in 7.4.9.
my interpretation is: of course it has to withstand the shell test pressure, but it's not to be regularly tested (hence, operating it does not invalidate the shell test)
what do you guys think
10.11.4 Testing
