This is one drawback of using patterns. You have to send the pattern file out with the part file if you want someone else to be able to use the drawing. Did the client include the pattern file in the data package? If so, open it before you open the drawing file. The drawing file should then open with the pattern in place. If not, then you will have to request of them, or use your own.
