Hi Arun17,
My research interest is different, not alumina, but ceramic/metal brazed joint, anyway in the literature you can find there are other material couples and technology parameters achieving different results.
My question is, which mechanical teting methode are you interested: tensile test, simmetrical or assimetrical 4 point bend test, shear test e.t.c.? What are your requirements for the joints?
Again there were reported results by Members of the Metals and Ceramics Division, Oak Ridge National Laboratory, Oak Ridge, Tenn as follow:
J.P. Hammond, S.A. David, and M.L. Santella : Brazing Ceramic Oxides to Metals at Low Temperatures, Welding Research Supplement (1988) pp. 227-232, have been publishing results of joints Al2O3/TiC-Ni interface at room temperature shear strength of 233MPa, Al2O3/Nb-1Zr interface at room temperature shear strength of 125 MPa, Al2O3/Ti interface at room temperature shear strength of 78MPa
Can you access some database e.g. Cambridge Scientific Abstract, Weldasearch, Materials Research Database or Metadex, Ceramic Absracts, AWS, or Edison Welding Institute?
Do Nascimento, R.M.; Martinelli, A.E.; De Almeida Buschinelli, A.J.; Lugscheider, E.; Sigismund, E.: Microstructural evolution and mechanical strength of metal alloys brazed to alumina mechanically metallised with titanium,
Source journal: Welding and Cutting (2004) no.2, pp. 96-102
Published by German Welding Society: DVS Verlag Düsseldorf
Contact person: Carolin Hesse
I wish you good luck: Leonora
