Tire spring rate effect
sbrats
CA
My question is from a position of little background, however with the appearance of high rate suspension to keep chassis platforms at a constant ride height, I would think that the tire rate (sidewall) would become into play. The springs are controlled by the dampers, if the tire rate has an effect what or how does this come into play
S
The tire stiffness acts in series with the effective spring rate at the hub.
Cheers
Greg Locock
Yup! Springs in series. If the suspension spring would appear to provide a wheel rate of 222.22 pounds per inch, but the tire has a rate of 2000 pounds per inch, actual wheel rate would be 200 pounds per inch.
As for damping. 'most everyone has dribbled (as in basketball) a tire and wheel assembly across the shop floor at some time or another, so we know there's not a whole lot of internal damping in the tire. Good thing, of course, or we'd be throwing treads from the heat buildup.
Perhaps someone closer to the sport can provide more information, but I heard rumors that, before rule changes to limit aero downforce, designers of Formula One cars were considering eliminating the chassis springs entirely. Don't know what International Karting Federation class they would have fallen into.
