Tip for importing sketch data from a file
  • Thread starter Thread starter bhayden
  • Start date Start date
B
bhayden
Guest
I've found that importing data from a file (.dwg format) the geometry often gets mangled. I'd like to offer this tip/work around. After you select and open the .dwg file the geometry appears floating somewhere on your screen and you are given a dialog box to pick scale and rotation. Like when sketching, the geometry is usually super sized. I haven't clue why the default scale isn't set 1:1 but anyway if you just accept the default the geometry comes in much cleaner.
I thought this might be because of the way the Intent Manager dimensions the entities. Again, I can't think of any good reason but if you turn off intent manage then the option to import geometry from a file is greyed out. The interesting thing is that if you accept the default constraints (I made them strong dimensions) and then do Modify > Lock Scale the geometry scales correctly.
Looks like a bug, walks like a bug, must be a bug. BTW, I tried the same thing in Wallflower and got the same result. They may have changed the mouse interface but at least they left it bug compatable :+)
Bernie Hayden
XKL LLC
Thanks, it helps. I didn't know that. I always made the scale 1 and had problems with constraints. :-)
mvitez
