Hello all,
Im running a direct integration non-linear time history for a one story, steel frame building with sap vs 9.0.3 and noticed that I had the same displacement results when i used a plastic hinge with a value of say 100 ft-kips and one with 50 ft-kips.
Now this error can be to many things but i tried to look at the time history of the hinges and they are all blank for both analysis. In fact if i scale the ground motion to be 100 times stronger and then run the analyses i get the exact same result: no values displayed for the time history in the hinges. This is really odd and is occurring in version 9.0.3.
I have an odd feeling that this version of SAP does not display time history values for hinges, so what I did was import a model from SAP version 8.2.3 and ran that in version 9.0.3 which I know for a fact has values in its hinge time histories when i run them un 8.2.3. Low and Behold again no time history for this structure either with absolutely no changes. Whats going on? Is this a known bug in SAP 9.03?
Thanks in advance!
AR
Thanks in advance!
AR
