Hmmm,
I think the big difference between my approach and [blue]PEInc[/blue]'s comes down to a couple of key areas:[ol][li]Is load, or deflection, the more important criteria for evaluating wall performance?[li]How should wall performance be measured?[li]How much reliance should be placed on specialty contractor data and claimed experience?[li]Who really bears the risk should a wall fail to perform as expected. and what role should the assessment of risk play in the structure's design and construction?[/ol]In my view, the key measurement of wall performance is deflection. After all, it's the wall deflection that will allow loss of ground and damage to adjacent structures to occur. The magnitudes of the loads on the wall don't matter if the wall experiences excessive movement. We have to focus on the effect that really matters -
Wall performance should be measured using a combination of devices, including inclinometers, weldable strain gages, load cells on anchor rods, and Mustran cells. Precision surveying is also key, and it must be referenced to a stable benchmark that is unaffected by the construction work. Calibrated jacks don't provide very good data, and anchor loads alone are not a sufficient basis for evaluating wall performance.
I am very careful about which specialty contractors I trust, and how much I rely on their "experience". I think a healthy dose of skepticism is needed in evaluating the contractor's opinions and data. Hell, I do the same thing with data 'promoted' by my peers, so I'm not picking on the "poor contractor."
Who bears the risk of failure? Generally, the owner is exposed to the greatest financial risk. The GC and specialty contractor also bear some risk, although they frequently avoid much of their responsibility for a variety of reasons. The design team may also suffer even when the specialty contractor has provided their own sealed plans.
The key idea is to avoid problems - and the courthouse, if possible. How does one do that? Carefully choose your clients, do first-rate work, and - of course - be lucky!
Please see FAQ731-376 by [blue]
VPL[/blue] for tips on how to make the best use of Eng-Tips Fora.
