sundancekid
I have a problem with a panel bowing -- possibly due to solar heat gain in the late afternoon. This problem is most apparent at the corner where this panel is the “long” panel at the corner and it meets the straight edge of the “short” corner panel.
Facts:
Location – Atlanta, GA
Age of structure – 3 years
Wall exposure – west north west
Wall ht – 34’ AFF and 4’ dock ht.
Wall finish – exposed concrete with arch. form liner finish
Amount of permanent bow – bottom 0”, mid-point ½”+, top 0” (this has progressed over time)
Panel thickness – 9” total (8-1/4” if you deduct for arch. form liner)
Interior use – warehouse – heat only
Roof load – nominal (barjoists run parallel to wall)
Misc. Note – there is a corner crack that is apparent from the interior only across the bottom corner (6 feet) of this panel (it does not seem to be moving or to be contributing to the bowing issue)
Over the last three years the ½” plus bow in this panel has become permanent and I have the following questions:
Q1- is there some other potential problem besides thermal gain that I should be looking at?
Q2- Do you have any ideas that I can pass on to our structural engineer on how to fix this problem?
Q3- Will this wall continue to bow out more & more with time?
Facts:
