TIA 222 (Steel Antena Tower) - Design force lookup 2
SRO
104
My copy of TIA 222 "Structural Standards for Steel Antenna Towers" is missing Annex B: U.S. County listing of Design Criteria.
Does any one have this standard that could make a copy or pdf of this table for me? The full table would be nice, but the couple of pages that the Massachusetts information will work fine.
Since quite extensive (many pages) would be better give state and county for the page.
Best wishes
The entire table would be great (if anyone has excessive holiday spirit), but I agree it is alot of pages. So if I could get the 12 counties of Massachusetts which should only be two pages that would be a big help. If that is two much of an inconvience then the only county I REALLY need for this job is Barnstable, MA.
ishvaaag...that's worth a star!! I'm sure SRO thanks you as well.
ishvaaag, Thanks a Million!!!
Which version of the standard are you looking for (F or G). Make sure you use the County listings for the correct code. The F standard was based on fastest mile wind speed whereas the G standard was based on 3 second gust. Therefore, the values are quite different.
That was the on I needed.
ishvaaag, thanks again
JoshPlum, thanks for the clarification
