Thrust Washer 1
uptick
Can we use a regular washer (good material) as a thrust washer for end play (axial movement of the shaft)? Thanks,
uptick.
endplay of an internal shaft in an automotive transmission?
Thanks ivymike,
use on throttle valve's shaft.
uptick
It really really really depends on the application, the load, the speed, the surface areas, the lubrication, the surface finishes, the mating materials etc etc etc
Pat
for site rules
might be posted in the wrong forum... perhaps "mechanical engineering other topics" would get your answers.
Thanks ivymike. I did post there.
