I am doing a solar panel on roof design. I have been asked by the plan checker to show the analysis of the thrust on this system. I must admit I’m not exactly sure what “thrust” is in this context. Is this additional outward force applied to the walls by an increase in load on the roof?
This particular residence has two roof shapes,
1) Typical roof, with rafters, rafter tie, collar tie
2) Vaulted ceiling with rafters, beams and intermediate columns supporting beams.
In condition 1, there would be no thrust as the load is being handled by the tension capacity of the collar tie.
Pinned left side, roller right side.
I would go under the assumption there is no additional thrust in condition 2, because all the load is being directed downward through the intermediate columns.
Pinned left side, all other reactions are rollers
Based on what I’m seeing, there isn’t a reaction in thrust, unless make both ends of each rafter pinned. Is that the right way to determine loading? Thank you.
