My argument about tolerancing and inspection still stands.
(getting on soapbox)
You could call out the hole as .50 deep +/-.25 and it would still be uninspectable. You can't inspect something that isn't there, and the bottom of that hole would not exist. It would be impossible to confirm that the hole depth fell between .25 and .75. It may be drilled .23 deep, be fully functional, yet be uninspectable, negating ANY inspection or definition value of that tolerance callout. If the dimension has no value to the part definition, it has no place being called out as a hard dimension. As the designer, you don't care WHAT the depth is, as long as it is thru to bore. Isn't that what a drawing is supposed to do- define the part, not the way to make it?
(Getting off soapbox)
There are exceptions to this, as most things. A deeper, smaller hole intersecting with another hole of similar size would need to be tightly controlled. But that does not involve a bore, and is another situation all together.
