Thru hole without the THRU annotation
  • Thread starter Thread starter EvilFlo
  • Start date Start date
E
EvilFlo
Guest
Is there a way for CREO to not display the word THRU in the callout when I have a thru hole?
You will need to create a custom note since, by default the hole notes call up the depth of the hole & the thread if using the hole tables - however if you don't use the hole table, you don't get a hole note unless you specifically create a setup note attached to the hole.
I never use the notes that Creo provides.
They are too long and contain unesecessary information.
