Some of you may remember I have been looking into running my new motor on propane, and not using any sort of air throttle. Goal was to regulate power through fuel delivery, taking advantage of propane's excellent lean burn limits and near perfect atomization.
Before any testing I knew the biggest hurdle would be idle. The fear was that power could not be reduced enough through a super lean mixture to keep the engine at a reasonable idle speed. Beyond this, it may have turned out the mixture couldn't even be reduced enough for mild load situations (steady cruise, light acceleration).
The test I conducted this weekend put these fears to rest.
The test motor was a 3L, V6, 8.5:1 compression, motor on my wife's car (93 Dodge Shadow). Note the intended usage motor will be a 3L, I6, 10:1 compression. The motor was warmed up on gasoline. Then shut down. Fuel injectors were disconnected, and the throttle stuck wide open. A 500000BTU/hr propane torch was then inserted into the open throttle. While the engine was being cranked over, I opened the valve on the torch. After about 1 turn, the motor started without hesitation. It did not run away. Rather it stayed at about 800RPM. I then experimeted for a minute, increasing and decreasing the propane flow, and noting I had perfect control of the idle speed. More propane, motor sped up. Less, it slowed right back down. It never stalled, popped, or backfired. Finally shut off the valve and the engine instantly shut down. I do note however, that it ran a little rough, with a slight misfire.
My conclusions from this test:
Load control through fuel delivery won't be a problem. The low end of the lean limit range without misfire goes very low indeed. I have no doubts I can have mild accleration and steady cruise on all 6 cylinders without misfire or rough running. Perhaps, with the improvement from the test 8.5:1 to the 10:1 of the motor the full system is intended for, may be able to lean idle dead steady without any misfire. Also consider I had a fixed ignition advance of 15BTDC on the test motor, and will have complete control over timing on the actual motor. This could help as well. I'm not counting on that however.
I have two other options available to me to keep the motor down at a idle speed when desired.
1. Fuel cut rev limiter. I'd set my fuel map so that at 0% throttle input and 1500RPM, the fuel injected would be at the very lean limit of steady, no misfire operation. However, this will probably be slightly more power than what is needed to keep the engine purring along at 1000RPM with no external load and full atmospheric pressure in the intake. I'd use a second rev limiter (available on my fuel computer) to kick in a fuel cut only, to keep the revs down. The limiter is very adjustable, having a 0-100% level of effect in two seperate stages, as the engine revs above the targeted limit. It wouldn't be a terribly hard rev limit like you are used to thinking about either, as most likely less than 25% of injection events will need to be dropped out to keep the revs steady, rather than the 75-90% of injection events on a regular engine running full stoich or richer. Before you mention, the propane is individually port injected, which is why I can do this.
2. Run the engine on two cylinders at 0% throttle. Simply run the engine on cylinders 2&5 only (firing order 360 apart). My fuel computer can easily be made to do this as well. To maintain idle speed, I'd guess those two cylinders would probably need to run at 75-100% of stoich. Anyone care to comment if this would cause harmful vibrations, harmonics, or some other concern?
