Hi guys,
According to my CIBSE reference, a three way valve on a coil needs a balancing valve on the bypass line along with one in the return line back to the chiller/boiler. That bypass valve gets set to provide the same dP as the coil when in full bypass mode.
Whats the point? at part load say half the water going through the bypass the hydraulic resistance would be half (two resistances in parallel) so you will still be in overflow. On the other hand if you have a high dP coil on the index run (small dP on the balancing valve) and no bypass bal valve then you will be in even more serious overflow.
Does anyopne have any thoughts on this? Has anyone seen an arrangement without a balancing valve in the bypass??
