Threads rolled vs cut
NDimitrov
12
Hi all,
the answer to my question is in almost every engineering book, but how far off are single point cut threads from rolled ones ?
To my knowledge the best scenario, regarding strength and fatigue life is rolled threads after heat treatment,
but that's quite difficult to achieve in the home shop for external threads .
So my main question is how would you approach making studs in the home shop ?
Kind regards
If you have to make them, cutting them with a lathe or die is your only real choice.
And this has what to do with Engines and fuel? Its more of a Machines and Machining question.
"how would you approach making studs in the home shop ?"
You can buy threaded rod in ridiculously long chunks, made to thread and material/bolting standards of your choice, from most fastener houses. Cut them to length, chamfer the ends and chase the threads, done.
You can roll threads on a lathe.
They sell roll dies that mount like a tool bit.
Just note roll threads require major diameter to be modified. Google dimensioning f I r roll threads. Or consult sales eng to help you with the correct calcs. You will need to run test
To get correct size.
I recommend to buy a set of go and no go gages,
Verify size . Second option is to have it thread ground from solid. Just machine tiny centers at each end.
