timsch
- Oct 27, 2009
- 192
I have a customer that wants us to design a bypass chamber with an odd drain configuration. We have a pipe with a short radius elbow butt welded to the bottom of the pipe and they want a hole bored into the side of the elbow to attach a threadolet, which will then have an extended body gate valve attached for a drain. Our bypass chamber designs typically are per B31.3. Where in the ASME codes would a modification such as this be addressed?
Material - A-105 CS
Design pressure - 95 psi
Design temp - 725F
Flanges - 300#
hydro test - 1125 psi
Material - A-105 CS
Design temp - 725F
Flanges - 300#
