Threaded holes in Solid Edge V10
  • Thread starter Thread starter -
  • Start date Start date
Guest
Is it possible to make NPT holes in Solid Edge V10? It is simple to make threaded shafts with the tapered pipe threads. But, the only way I can make NPT threaded holes is to make a theaded nipple, insert it into the part file that I want to have the hole, and use a boolean subtraction to get the threads. There must be an easier way!
