potrero
- Aug 30, 2007
- 516
A long time ago, I posted this question but got no answers ( thread561-225709 ). If anyone has a tip on how to get this to work, I'd appreciate it. We create parts and draft in metric, but often, we have inch holes and threads. It'd be very useful to be able to put the inch spec on the drawing sheet, which is otherwise a metric print.
"I have a metric part with an English threaded hole. When creating a metric drawing, how can I inherit the proper threaded hole callout onto the print (ie: 1/2-13 x 16mm or similar)?
I have tried using the "Feature Parameters" tool, but the thread callout comes in as "1/2 x 1.95" as in 1/2" x 1.95mm pitch...
When using the Feature Parameters tool, selection of the standard "ansi" option is greyed out, leaving only "ansi-mm", "iso-din", and "jis".
I'd appreciate help on this. Thanks."
