Hi aleavol (Aeronautics)
This is for your information
Engineering Case History
Case 13: Large internal thread strip-out
Analysis helps when making the tough decisions
T. SOFRONAS, P. E., Consultant Engineer, Houston, Texas
Reference to Page 95, Hydrocarbon Processing February 2003.
Damaged threads on larger 1- to 4 in. - diameter blind tapped hole, such as found on compressor casings and vessel flanges, usually required a downtime to repair. Anyone can ask for a downtime. However, if a repair is not immediately required and the plant can be kept operating safely, shutting down could be a very expensive decision. These are the tough decisions engineers help make. This article demonstrates how a simple analysis can aid in this decision-making process.
Twenty 3-in. UNC-8 TPI stud were threaded into a ductile steel vessel flange. Some studs were accidentally removed during an inspection and eight of the 31 internal threads were damaged in several threaded holes. Could the vessel be put back into service or was an extended downtime required?
Consider a stud in a threaded hole (Fig. 1). The stud is steel and the part is ductile steel and has a shear strength of ó shearpart , which is less than the stud, L is the engaged length at which “strip-out” of the threads in the part could be expected, D is the stud nominal diameter, P is the load in the stud and k = 0.9 converts the nominal diameter to the stud stressed diameter.
Now at complete yield conditions of the thread, the load is pretty evenly distributed along the threads. This is different form normal elastic conditions, where the first few threads can take up the shear strength, ó shearpart, is about one half of the yield strength, The failure stress, ó fail, can be approximated as:
ó fail = ó shearpart P/L share = P/ðkDL
The thread length that will strip-out is:
L = P/( ðkD ó shearpart)
Nominal stress, ó stud, in the stud due to assembly torque or stretch and any other loading produces the load
P = [ð (kD)²/4] ó stud
This simplifies to:
L/D = (0.225) ó stud /ó shearpart)
When ó shearpart = 17,300 lb/in², and ó stud 45,000 lb/in².
L/D = (0.225)(45,000 / 17,300) = 0.585
L = 0.585 x 3 = 1.76 in.
The threads could be expected to start to strip out when the engagement was 1.76 in. the remaining engagement is 23 good threads divided by 8 tpi or 2.88 in. there is adequate margin (2.88/1.76 = 1.64) and stripping-out isn’t expected.
Analyzing thread stripping is a complex subject and has to be blended with experience and common sense. While this analysis was verified with a nonlinear finite-element model, performing a risk assessment that determine the consequence of a thread strip-out is always prudent, Will a stripped threads result in a small, nonhazardous leak allowing an orderly shutdown? Or could a major leak occur, whit the potential for a catastrophic event? An analysis such as this provides quantitative input that can be used to help make the final decision.
1. Sopwith, D.G.., “The Distribution of Load in Screw-Thread,” Institution of Mechanical Engineers, Proceedig, V159, 1948
