Our current application is a 17-4PH Condition 900, 150 KSI min. Y.S. passivated bolt (socket head cap), with 5/8-11UNC screw threads that threads directly into a 316L base weldment on an ocean going vessel. This bolt is holding a roller assembly on a Helicopter Hangar Door, so it is exposed to a salt-laden atmosphere.
Over time the sailors try to remove the bolt, and it is shearing off clean right under the head (90 degree shear plane). I suspect the bolt threads have 'cold-welded' themselves to the 316 tapped holes. It looks like anti-seize was applied to the threads, but to no availe.
I'm thinking of possibly chrome-plating the threads, to improve hardness and surface finish, while retaining corrosion resistance.
Is this the right approach, or should I further investigate corrosion versus thread galling as the mode of failure?
