Thief Hatch &Vent 1
egebull
Chemical
Can anybody tell me how to check if a vent and thief hatch combined on a 400 bbl atmospheric storage tank will be sufficient to relieve any sudden pressure surges/vapor breakthrough?
Thank you,
In theory the psi to open the thief hatch is [weight of lid (lb)/lid area (in2)].
The hinge offers additional resistance to opening.
The hinge force is hard to predict due to friction & rust.
There are also possible spring forces depending on the model.
Any resulting flow through the device must be reduced by 50% (per OSHA) because it has no vendor calibration.
Using a thief hatch to "officially" protect a tank from overpresssure is highly questionable.
As an engineering professional my recommendation is to put aside this activity.
API STD 2000 / ISO 28300 will give you guidance on calculating required venting requirements.
