Rusty55125
Does anyone have a simple equation to calculate the steady state temperature inside a box knowing the insulation qualities of the box, the initial temp, surrounding temp as well as the heating source?
I am trying to do a rough calculation on what temperature will be achieved inside this sealed box if I have a know heat source and box insulation qualities. I am not looking at accurate numbers, just a comparison of different possible heat sources and what effect they might have. I will be going some experimentation on the current heating source so I have a basic understanding on what to expect if I change the heating source.
The box materials are a simple polypropylene, the heat source is a lighting ballast 50watts and the outside temperature is 72F.
Any help would be appreciated.
