I have been attempting to do a sequentially coupled thermal-stress analysis and I keep running into problems with the thermal data transferring from the thermal analysis to the mechanical analysis. This is procedure I am doing right now.
1. Run heat transfer analysis
2. Copy model and delete heat transfer step and use the same mesh for the stress model. Then create a stress analysis step.
3. Apply the temperature data to the stress analysis model using a predefined field.
Is this the correct way to do this or should I be using some other procedure such as defineing all the steps in one model?
