To reduce residual stresses from cold working the stress relief is benefitial to prevent SCC. To avoid sensitization the heat treated SS use shall be limited to operating services bellow 510ºC.
"Stress Relief: Optimal time and temperature for stress relief are reported between 1550° F. and 1650° F. (843° C. and 899° C.) for about 2 hours. Commonly, stress relief PWHT is performed on TP 347 stainless steel piping between 1550° F. and 1650° F. (843° C. and 899° C.) to reduce residual stresses from cold working and/or joint restraints, and to further reduce the susceptibility to chloride stress corrosion cracking.
Unfortunately, the stabilization heat treatment can also lead to substantial degradation of mechanical and corrosion properties because of complex physical-chemical interactions. For example, currently practiced stabilization heat treatment at 1650° F. (899° C.) frequently maximizes the rate of fine niobium carbide formation and allows for sigmatization of most remaining ferrite, often leading to substantial loss of ductility and elevated-temperature creep strength. Therefore, to prevent failure during high temperature service, heat treated stainless steel use is generally limited to uses with operating temperatures below 950° F. (510° C.) to ensure immunity to sensitization"
Thank you for your replies
LM
