Thermal Expansion
TurboME
Automotive
What is the best way to quantify the effects of using an ASTM A193 B16 alloy stud with a threaded 1018 steel flange?
The thermal expansion coefficient of the stud is about 14 F^-1 and 1018 is 6.7 F^-1. Is there a standard regarding this? Is this difference something I should be concerned about?
The application is an automotive exhaust system so temperatures will cycle over 1000 deg F.
There is little difference in the thermal expansion characteristics between an ASTM A 193 Grade B16 stud and low carbon steel. The coefficient of thermal expansion for a typical 1018 carbon steel is 7.72 micro-inch/inch at about 1000 deg F. In comparison, the ASTM A 193 Grade B16 will be approximately 7.5 micro-inch/inch at 1000 deg F.
The ASTM A 193 stud material is a low alloy steel containing vanadium. It can be used at 1000 deg F. The AISI Type 1018 will oxidize over time and not last long. Most exhaust systems today use a ferritic stainless steel versus carbon steel.
Thanks for your reply. The data I looked at for B16 must have been in units of deg C not F.
There are a number of OEMs that are going to A286 for exhaust studs to retain tensile strength at 1200 F while not having problems with corrosion and scaling. I don't know if you will need this much performance, but they work very well (although they are more expensive).
Dick
