I need to bond a thick wall brass cylinder, ID 0.500", over an aluminum cylinder, OD 0.497" using red locktite. Brass cylinder wall thickness is 0.11". There are no external loads on the assembly. I have calculated the differential expansion of both over the operating temp range and found there is a max diff of +/- 0.1 mils. The rate of change in temperature is a maximum of 10C/minute. Will the stess built up in the assembly weaken the bond joint over time?
Is a press fit without locktite a better solution?
wayt
wayt
