corus;
an earlier post suggested a 800F temperature difference between id and od. Such DT's across a wall thickness are rare , but possible in a radiant furnace of a large boiler firing oil and the waterwall tube heated one side by a flame at a radiant heat flux of about 125,000 btu/hr/ft2 and the back ,unheated side of the tube cooled by low temp liquid which is flowing at a rate less than required to avoid DNB. If immediate burnout does not occur , the hot OD facing the flame will want to expand but will not be able to due to restrained by the watewall membrane panel and the massive cold side buckstays- the result is yielding on the hot side of the tube and eventually a circumferential crack .
yielding occurs whenever the stress imposed by the DT and physical boundary conditions prevent relief of the stress. Such yielding occurs with a DT over 200F for most ferritic alloys, and certainly at lower DT's for austenitic steels with a lower yield stress and a higher thermal expansion coefficient.
But i repeat the heat transfer problem needs to be solved first - the example I give here is unusual in the extreme
