JourneymanEng
- Oct 10, 2002
- 5
Hello all,
I have an interesting problem with a micro GT and Recup combination.
Background:
Thermal expansion is wreaking havoc with bellows and pipework. I suspect a combination of unrelieved stresses in the fabricated pipes, and an incorrect config for the bellows.
Problem:
I would like to measure the thermal expansion of the entire system and need an idea of the correct apparatus & method for such an experiment.
I know i will need to start with a datum that is fairly even temperature (got it). Then need to measure specific points on the assembly during the course of combustion (know the points).
Specific problem: I will need to ensure all measurements are accurate but have a budget and limited time. In a past life i worked for the aircraft industry and made good use of theodolytes for measurement.
Is there a standard no-messing-about way to get an accurate idea of what a large assembly of metal is doing under thermal expansion?
Background:
Problem:
