Dears,
I have double pipe heat exchanger with cold ethylene flowing in tube side at 55 barg and 10 C; it is heated by LP steam (1 barg, in shellside) to 35 C. The duty of the heat exchanger is Q = 2219 kW (normal conditions).
If the cold high pressure ethylene is blocked in the heat exchanger between the isolation valves of it, thermal expansion of the fluid might occur. The heat exchanger is proteceted by a Relief Valve set @ 66 barg.
My question is: does anybody know how to calculate the relief flow and the relief temperature for this case?
I did it with the following methods, but the results are completly different.
1: Relieving flow for thermal expansion of GASES:
M = Q x [(ro2 - ro3)/ro2]/(h3 - h2) , kg/h where: 2 is for relieving temperature and 3 is for relieving temperature +1 C.
- the relieving temperature was assumed to be maximum shelside temperature (120 C)
2. Isochoric flash:
Considering a fixed volume (HX pipe + additional pipe) in which the fluid exists, a mass of fluid at operating temperature is calculated based on the density, m=ro(actual) * V(system).
Then, the fluid is brought to the set pressure and the temperature is modified till the volume of the contained fluid a9based on initial mass) is equal to the volume of pipe (this is the point where the RV starts to open). Choosing Dt=1s, the heat Q=2219kWx1s = 2219 kJ is added to the system. The new volume is calculated at the temperature where the valve starts to open + the temperature increase due to the heat input (Trelief = Tset + DT, where DT = Q/(m*Cp) x 1s)).
The relief flow is: m = ro(v) x DV/Dt , kg/s
I incline to use the second method even if in the attached file the example assumes ideal vapor phase.
Could you please let me know you opinion?
Thanks!
2. Isochoric flash:
Thanks!
