RJB32482
Chemical
- Jan 19, 2005
- 271
My question is on thermal expansion compensators that have bladders precharged with N2 on the unwetted side. What is the hazards with having the charge too high or too low of a pressure relative to the normal operating pressure of the system? Would too high cause not enough volume to go into the compensator? Would too little cause the compensator to fill even while pumping (if compensator is vertically mounted and no valve on the bottom while pumping through main lime)?
Any learning would be helpful.
Thanks.
Thanks.
