Thermal Expansion Analysis
  • Thread starter Thread starter tstergioula
  • Start date Start date
T
tstergioula
Guest
Hi Everyone,
I have a small problem and i would be very greatfull if someone can help me. I am using pro Mechanica for a couple of time and i would like someone to check my work because i am the only person i use Pro mechanica in my workplace. I attached a pdf document with my questions and details in my problem. I would appreciate if someone has the time to review it and tell me what he thinks.
Best Regards,
Thomas
2012-04-12_122023_ALUMINUM_BEARING_HOUSING_WITH_STAINLESS_ST EEL_INSERT.rar
Edited by: tstergioula
Its hard to decipher your analysis but things to check
1. interface displacements are same for housing and
sleeve
2. interface pressure are same for h & s
You've got very close with your hand calc - check your
interface stress as well. The housing out-of-round is
small only 8micron - could be from non-uniform stiffness
of housing or placement of measure.
Be careful where you place your measures - try and
measure away from edges. Position of Z constraint may
also affect results. Check effect of mesh density thru
sleeve
